Country: Production Operative
-on in the shared modern C++ and Python simulation codebase. Implement scoped features and integrate driving-stack components...'s simulation system using modern C++ and Python. Integrate driving-stack components, simulated robot systems and new vehicle...
SENIOR SOFTWARE ENGINEER Catapult is building the future of sports performance technology, with a mission to Unleash... We are looking for a Senior Software Engineer to help build the Perch camera system, Based in London (hybrid), you will work across platform...
or velocity control. Senior Software Engineer essential skills 3+ years relevant software engineering experience with C or C... in engineering or equivalent qualification or experience. Senior Software Engineer desirable skills Python RTOS Linux...
Software Engineer | Defence Start-Up | London Software Engineer required for an early-stage defence technology start... Development experience Proficient in Python, TypeScript, Rust, Go, Java, or C++ A true generalist - comfortable working...
and debugging software in C++ and Python. Experience with autonomous or robotic systems, including familiarity with areas...The Systems Engineer, Autonomy & Software at Shield AI is responsible for solving complex systems engineering...
pipelines, and test infrastructure in C++ and Python Support software bring-up, system configuration, and mission readiness... for robotics, autonomy, aerospace, embedded systems, or related technical fields Strong software engineering experience in C...
++ or Python experience would also help you contribute to supporting software and tooling. 🌱 Not ticking every box... is building embodied AI that can drive any vehicle, anywhere. Within Robot Software, the Platform Integration team brings together...
software with modern C++ over embedded systems. \n RESPONSIBILITIES Implement, deliver and refine Arene SDK software...-agnostic software platforms using modern C++ concepts Collaborate with global teams to accelerate and improve Arene software...
As a Senior Robotics Engineer, you’ll bring your technical experience and engineering judgement to the development of robotics..., mapping, path planning, mission execution and safe navigation. Are confident developing in Python and/or C...
software and control logic using relevant tools, such as Python, C++, PLC programming, or robot programming environments.... This is a hands-on mechatronics role spanning mechanical design, electrical integration, software, and control. You will bring these...
